Самсунг сегодня представил новую систему, подобную Micro Four Thirds.Подробности на dpreview.Подробных данных о камере пока нет,есть только фото первой камеры новой NX серии.С блинчиком смотрится не плохо.
добавлено 31.01.10
Спецификации с сайта производителя:
http://www.samsung.com/us/consumer/photography/digital-cameras/nx-series/ES-NX10ZZSEB/index.idx?pagetype=prd_detail&tab=spec
Image sensor
• Type CMOS
• Effective Pixel Approx. 14.6 Mega-pixels
• Total Pixel Approx. 15.1 Mega-pixels
Lens
• Mount Samsung NX Mount
• Usable Lens Samsung Lenses for Samsung NX Mount
Viewfinder
• Type EVF
• Field of View Approx. 100%
• Magnification Approx. 0.86x (APS-C, 50mm, -1m-1)
Focusing
• Type Contrast AF
• Modes Single AF, Continuous AF, MF
Shutter
• Type Electronically controlled vertical-run focal plane shutter
• Speed Auto:1/4000sec. ~ 30sec. Manual:1/4000sec. ~ 30sec. (1/3EV or 1/2EV step) Bulb (Limit time : 8 min)
Exposure
• Compensation ±3 EV (1/2EV, 1/3EV step)
• ISO Equivalent Auto, 100, 200, 400, 800, 1600, 3200 (1EV step)
• Modes Single, Continuous, Burst, Self-timer, Bracket (AE, WB, PW)
• Metering System Metering : Multi, Center-weighted, Spot Metering range : EV0 ~ 18 (ISO100•30mm F2.0)
• AE Lock AEL Button
Flash
• Modes Smart Flash, Auto, Auto + Red-eye reduction, Fill-in, Fill-in + Red-eye reduction, 1st Curtain, 2nd Curtain, OFF
• Type TTL Auto Pop-up flash
• Guide Number 11 (at ISO 100)
• Angle of View Coverage 28mm wide-angle (Equivalent to 35mm)
• Sync. Speed Less than 1/180sec.
• External Flash Samsung External Flash available (SEF-42A, SEF-20A : Optional)
Effect
• Picture Wizard Yes
• White Balance Auto, Daylight, Cloudy, Fluorescent (W, N, D), Tungsten, Flash, Custom, K(Manual)
Shooting
• Modes Smart Auto, Program, Shutter Priority AE, Aperture Priority AE, Manual, Night, Portrait, Landscape, Scene, Movie
• Drive Modes Smart Auto, Program, Shutter Priority AE, Aperture Priority AE, Manual, Night, Portrait, Landscape, Scene, Movie
Storage
• Media SD, SDHC
• File Format RAW (SRW), JPEG (EXIF 2.21), DCF, DPOF 1.1, PictBridge 1.0
• Capacity (512MB)
14M : RAW 35
14M : Super Fine 142, Fine 278, Normal 408
10M : Super Fine 197, Fine 382, Normal 724
6M : Super Fine 322, Fine 615, Normal 1128
2M : Super Fine 738, Fine 1334, Normal 2238
Burst (1.4M) : Super Fine 1201, Fine 2092, Normal 3320
12M(W) : Super Fine 168, Fine 328, Normal 630
8M(W) : Super Fine 234, Fine 454, Normal 860
5M(W) : Super Fine 381, Fine 727, Normal 1334
2M(W) : Super Fine 872, Fine 1573, Normal 2638
Movie : 1280x720 : High Quality 15min., Normal 22min.
640x480 : High Quality 44min., Normal 66min.
320x240 : High Quality 145min., Normal 210min
Image Play
• Editing "Red eye fix, Back light comp., Photo Style Selector, Resize, Rotate, Face Retouch
• Type Single image, Thumbnails (3/9/20 images), Slide show, Movie
Interface
• Digital Output Connector USB 2.0 (HI-SPEED)
• Video Output NTSC, PAL (user selectable) HDMI 1.3 : (1080i, 720P, 576P / 480P)
• DC Power Input Connector DC 9.0V, 1.5A (100 ~ 240V)
Power Supply
• Power Source Rechargeable battery : BP1310 (1300mAh) Charger: BC1310 AC Adaptor : AD9NX01 (Optional)
• Battery Life 200min/400shots (CIPA Standard)
Physical Specification
• Dimensions (WxHxD) 4.23"×3.43"×1.57"
• Weight 0.77 lbs.
• Operating Temperature 0 ~ 40 °C
• Operating Humidity 5 ~ 85%
фото:
Samsung NX названы возможные спецификации
Всего 2893 сообщ.
Samsung Micro Four Thirds!
Re[Madarashi]:
Ошибка! Это не микро 4/3, а APS-C!
Re[Игорь Тулаев]:
Нда уж, название темы надо бы поменять
Re[Madarashi]:
Не, ну чо, всё закономерно.
APS-Cшки подешевели, и просьюмерки начинают возрождаться как класс.
Сие зело богоугодно, ай мин.
Re[dh.sale]:
от: dh.sale
Это не просумерка , это камера со сменной оптикой.
Re[Велобайкер]:
от: Велобайкер
Я бы даже сказал, прямая замена "зеркалок"... ;)
Re[Madarashi]:
Собственно, никаких неожиданностей - то, что такие камеры просто обязаны появиться, было вполне очевидно. Способность Самса сделать такую тушку у меня сомнений не вызывает... Вопрос в сменной оптике под новый стандарт. Кто ее будет делать? Чем планируется закрывать дыры, пока линейка не нарастет? Пентаксовским КAФ? А переходник что, с моторчиком под отвертку делать? Сколько же он тогда стоить будет? Или в нем самом отвертка сохранилась? Или вся ставка - на ручной М-маунт и ЛТМ?
Из релиза я пока ни черта этого не понял.
Re[Madarashi]:
Сильно удивился, что там вовсе не "Пентакс байонет".
Может он еще сделает адаптеры на все байонеты?
Это было бы кру-у-уто!
Также там нет "качалки" цифрового зума и похоже этот аппаратик будет претендовать на что-то серьезное. (Если первый блин комом не окажется).
Но расположение кнопок могли бы и по удобнее сделать. Или все прочие комбинации кнопок на тушках забиты патентами на 100 лет вперед?
P.S.
А ведь в случае грамотной реализации своего концепта Самсунг мог бы угробить конкурентам половину рынка ЦЗ начального уровня. :?
Боюсь только опять чего-то недодумают там до конца. Не японцы, которые мастера в доводке всех разработок до ума (не будем о маркетологах ).
P.S.
Re[niklens]:
от: niklens
По картинкам похоже, что там даже нет встроенной вспышки! Конкурент "пятачка"?!
Re[niklens]:
от:niklens
Но расположение кнопок могли бы и по удобнее сделать. Или все прочие комбинации кнопок на тушках забиты патентами на 100 лет вперед?Подробнее
Не стоит забывать, что это всего лишь навсего концепт концептом, и бог его знает, как будет выглядеть финальная версия. Есть ведь еще и такие картинки в сети:
Re[niklens]:
А зачем там пентакс байонет - все равно без переходника не встанет.
Re[Madarashi]:
забавно
предвижу крики "наконец-то они избавились от УСТАРЕВШЕГО зеркала" )))))))
кстати, по мне так лучше бы они и электронный видоискатель обрубили вместе с выпусклостью под него
компакт так компакт
компакт так компакт
Re[Владимир Данилов]:
Этот концепт уже 5 лет просится на рынок. Как бы и сейчас не издох еще при рождении. :(
Re[Игорь Тулаев]:
почему нету вспышки?
есть вроде
http://a.img-dpreview.com/news/0903/Samsung/NX_Bk_FS.jpg
есть вроде
Re[XAMeLeoN]:
А если телевик захочешь установить, то "на вытянутых" визироваться будешь?
На такую камеру удобно суперширик ставить. Там высокопрецизионная фокусировка "зеркалом" не так нужна, как правило.
+ Экономия массы и габаритов в кофре не малая, помимо камеры с нормальным зумом и телевиком, ИМХО.
И еще просветите чайника, плиз: Там контакты на башмаке сверху под пыху от Пентакс или какие?
Re[niklens]:
от: niklens
ну не тот у не го уровень. Мне кажется это ниша как что-то типа лоуэнед. И телевик больше 200мм туда вряд ли станут делать ибо он там на фигш не сдался. А на 200 можно и с рук , тем более если воткнут стаб в тушку или в обьектив.
Re[niklens]:
Посмотрите внимательно на башмак по моему расположение контактов по сравнению с Пентакс изменилось!!!
Re[niklens]:
по этому поводу согласен с велобайкером ;)
от:Владимир Данилов
Есть ведь еще и такие картинки в сети:Подробнее
В данном случае мы имеем дело не с продуктом "народного творчества", а с официальной информацией!
Re[XAMeLeoN]:
А я против!!!
Хачу под ПРО оптику компактную прогулочную "немыльницу"
