Появился полнокадровый К 3
Pentax K-3 Announced
Full-frame, backwards-compatible K-mount DSLR · Posted on 04-01-2012 in Pentax News
It has been over a year and a half since we've seen a new DSLR from Pentax- the K-5 and K-r both came out in the fall of 2010, and the K-r ended up being discontinued in late 2011, prior to the announcement of its successor.
While we all expected the next DSLR announcement from Pentax to be about the K-z (the K-r's successor), today Pentax Japan surprised us all by giving us an early look the Pentax K-3, a new full-frame addition to their DSLR lineup. Together with this camera, which will likely not start shipping until this fall, Pentax will also be re-releasing many of their FA-series full-frame lenses as D-FA lenses.
The key specifications of the Pentax K-3 are outlined below:
Sensor: 24.0 Megapixel CMOS (36x24mm)
ISO Range: 100-25,600 (50-102,400 expanded)
Autofocus: 29-point SAFOX X w/light wavelength sensor
Shutter: stepless, 30s-1/8000s rated for 200,000 actuations
Framerate: 6FPS at maximum resolution
Video: 1080p/720p recording at 60/30/25/24 FPS, VGA recording at 120/30FPS
Image processor: Dual PRIME M
Media: Single SDXC/SDHC/SD card
Body Color: Graphite black
Note that these are tentative and based on initial reports; the official specifications have not yet been publicly published by Pentax.
The K-3 uses the same "crippled" KAF2 mount that's found on other Pentax DSLRs, meaning it's fully backwards-compatible with manual lenses, but needs to stop-down meter when one is mounted. Whenever DA (APS-C format) lenses are mounted, the camera will automatically switch to a 12-megapixel cropped sensor mode which only utilizes the APS-C image circle.
Professional photographers using the K-3 will be eligible for the PENTAX Professional Services program (PPS).
More Pentax news at: http://www.pentaxforums.com/#ixzz1qoSztr5P
Re[Gheorgii]:
Он не полнокадровый :(
Re[Gheorgii]:
бредовый фейк полуторагодовалой давности давно пора было удалить, тем более в свете выхода реальной К-3
модераторы тут вообще бывают?
Re[Gheorgii]:
Теперь это вроде как и впрямь новая камера (официально), но она не будет ФФ..((
Re[Gheorgii]:
http://bokeh.digitalrev.com/article/the-pentax-full-frame-dslr-is-awesome может пентакс и удивит своей камерой фф
Re[Gheorgii]:
Появился, но в 2016...
http://www.pentax.com/en/pentaxff/
Re[artemAG]:
Да!!! и это К - 1....в продажу с марта...9. Малый надежный корпус пыле- и влагозащищенной конструкции
Он принял легкий и прочный из магниевого сплава внешность передней и задней и нижней части основного корпуса. Кроме того, в то время как снабжен механизмом управления жалюзи, чтобы очистить тест на выносливость 300000 раз для удовлетворения профессионального использования (камера, установленная состояние), плавучим зеркала структура нового развития мы проводим миниатюризация размеров тела до предела. Кроме того, для достижения холодный производительность, чтобы обеспечить нормальную работу устройства до тех пор, пыле- и влагозащищенной конструкции и минус 10 ℃ использованием уплотнительного части 87 очков, она достигла прочный корпус, который не выбирать сцены съемки.
Re[FYII]:
https://www.youtube.com/watch?v=oQjGsTx4214
Re[Gheorgii]:
del
